Diesel Forum - TheDieselStop.com - View Single Post - Getting '2018 F350 Dually
post #11 of (permalink) Old 02-04-2018, 10:53 AM
HWarren
Originally Posted by davydee View Post
It's noted in the YouTube Video in this post on the FTE forum: https://www.ford-trucks.com/forums/1...l#post17558473
https://youtu.be/Ov1U-DYn3uM?t=134
Note that I said it was a wiring harness damaged due to heat from a valve cover. The video notes that it's a PCM Harness damaged due to rubbing on the EGR cooler, not heat related. I apologize for the error! Personally, I've still got a harness that's just barely raised off the passenger side valve cover that concerns me. At 20k miles, no problems so far - but I'm watching. David
I also have a 17. Will check mine and make sure it is raised. That is some great info much appreciated.
HWarren is offline
