Diesel Forum - TheDieselStop.com - View Single Post - Help! Looks like coolant in engine oil.
post #10 of (permalink) Old 03-30-2018, 10:37 AM Thread Starter
losfinch
losfinch's Avatar
Originally Posted by klhansen View Post
You might try pressurizing the coolant system to see if you can see where the coolant is coming from.
I might not be able to do that for several weeks unless I can locate a pressure tester locally with someone. However, since the coolant system is staying under pressure after being shut down and cooled off (for days) if there was leak or crack that I could find under a pressure test you'd think I could find it or hear it now as it sits under pressure, right? The way its under pressure after its been sitting fr a day or two when I take off the degas tank cap it feels and sounds at least as high or higher than it was running normally under water pump pressure on a normal motor.
How do they do compression checks on these motors...through the glow plug holes? If so, I'd need to get an adapter for that for my compression tester set I think. This would be in order to check for head gasket problems, correct?
Early 99 F350 4X4 CC 7.3 Auto. A.R.E. Topper, bed carpet/bench inserts, Rhino grill guard, AIS w/sleeve, Fuel filler mod, GOS headlight harness, 02-04 Headlights, Rancho HD stabilizer, 06 Telescoping/heated mirrors with C-Btr Mirrors, Hella FF1000, Htr Bypass valve, front receiver hitch, Quadzilla XZT gauges, ITP Pre-pump/In-tank mods, Pioneer P5000UB w/XM radio, 4 Infinity Kappa 682.7cf, Fumoto valve, FIAMM Highway blaster horns, SS HPX, IDM mod, DP F5 (Stock,Drive-thru,60T,80E,120,80E-Mountain,1200), Walker BTM, RR, Dieselsite BRV, BTS Tranny (2nd one :-), 31 row tranny cooler, Bilstein shocks, Amsoil bypass oil filter, Stancor HD Glow Plug Relay, billet thermostat housing, front & rear parking cameras, Aux reverse lights, Heated Seats.
Security: CrimeGuard Alarm with remote notification, DIY jimmi-jammers, door cylinder locks and linkage removed, padlocked rear bench seat hinge, PCM, DIY "pitstop" switch.
losfinch is offline
