Diesel Forum - TheDieselStop.com - View Single Post - No power unless at 2500+RPM
post #43 of (permalink) Old 04-07-2018, 02:27 PM
bismic
Sorry I hadn't responded. Too many irons in the fire.
Unfortunately the shorted injector coil issue can happen without a DTC being thrown.
You can disconnect the injector without tearing down the top of the engine.
I hear what you are saying about the turbo re-learn cycle, but P132b will be set if the PCM determines that there is something wrong with what it learned for MAP and MAF as it relates to VGT duty cycle.
Mark
bismic is online now
