While driving this morning, all of the cluster gauges went wonky.
They all cycled from min to max a couple of times, then stayed pegged out.
The windows, inside lights, both dome and map, and radio do not work.
Auto-headlights will not turn off when key is off.
It did this a while back and I was advised that it was the cluster.
I sent it in to https://circuitboardmedics.com/2002-2004-ford-super-duty-instrument-cluster-repair/
When I got it back, everything worked fine, for a couple of weeks.
The gauges and radio would occasionally reset, but everything would work fine after the reset.
This time, the affected items stayed stuck.
Was the cluster the problem and CircuitBoardMedics need to fix it again?
Or should I start looking for other issues?
