I would stick with what you have. 250 grand MPH means other issues, ball joints, U joints, Brakes, starter, alternator, and new tranny. Stick with what you have. You should have sucked it up form the start and did the studs while you did the other stuff. Are they pulling and milling the heads for that price?
DENNY
