Diesel Forum - TheDieselStop.com - View Single Post - 7.3L Won't start Super fast clicking sound
post #7 of (permalink) Old 08-30-2018, 07:50 PM
DonWarkentin
Originally Posted by ArcticDriver View Post
I think.both of you have valid points.
Heat is a killer but I think a frequent heavy draw on a lead acid starter battery also shortens battery life. Such as that from glow plugs and starter demands of a cold engine.
Proper battery and charging system maintenance by making sure all cable connections are bright & tight, cleaning posts, using felt washers, occasionally topping off with a goid charger, etc can all help to protect the batteries.
I have also read the common practice of trickle chargers is also a battery killer.
And, again, you guys are both right, 2-5 years is the typical life of a lead acid battery.
That's why I switched to Odyssey extreme 65-PC1750T batteries, because I was only getting two years per set of batteries. Hopefully, I will get at least six years with these.
DonWarkentin is offline
