Diesel Forum - TheDieselStop.com - View Single Post - '2000 XLT Door Locks
post #8 of (permalink) Old 09-01-2018, 11:14 AM
DonWarkentin
My power door locks work again. They hadn't worked in years. Once I put in the new Odyssey batteries, they started working again. I guess these batteries have so much power that the door locks work even though the actuators are weak. That was an unexpected bonus of the Odyssey batteries.
DonWarkentin is offline
