Diesel Forum - TheDieselStop.com - View Single Post - TPM Light
Thread: TPM Light
post #4 of (permalink) Old 09-04-2018, 11:33 AM
ford_doctor
ford_doctor's Avatar
If there is a fault with a sensor and the signal is missing the BCM will set a code for it that will identify the offending sensor. Of course this is dependent on the tires and TPMS sensors were trained with them in the current position. I frequently see this issue when cold werather first creeps in after someone has rotated their tires and set the pressures and not retrain the TPMS sensors.
A quick way to determine if you have a bad sensor is to enter the training mode and any sensor that fails to set... well you know.
2019 Ford Fusion ENERGI Titanium Plug-in Hybrid
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is online now
