Diesel Forum - TheDieselStop.com - View Single Post - Massive oil leak from passenger's rear of engine
post #11 of (permalink) Old 09-08-2018, 11:30 PM
DonWarkentin
I'm guessing you have leaks in several different places. Probably O-rings, pan gasket, and dipstick tube at least.
DonWarkentin is offline
