Diesel Forum - TheDieselStop.com - View Single Post - Failed Coast Clutch - Am I safe to drive In mountains?
post #5 of (permalink) Old 09-11-2018, 08:23 PM
Mark Kovalsky
Mark Kovalsky's Avatar
My Photos: (6)
Originally Posted by Graupp View Post
I got 'chatter' when backing up...
The coast clutch doesn't do anything when you're pressing the accelerator pedal in reverse. If you're coasting in reverse I could see how it would chatter.
I called Brian at BTS transmission, and scheduled an appointment in 2 weeks...
He told me NOT to use 1st gear and Reverse..at little as possible
I don't understand why. Once again, in reverse the coast clutch is only doing something when coasting. If you're in first gear with the OD OFF light not illuminated the coast clutch isn't even applied.
I don't know about 2nd or 3rd..though....
Same as first. If you don't press the OD OFF button the coast clutch isn't applied. It isn't doing anything, it's just along for the ride.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
