Diesel Forum - TheDieselStop.com - View Single Post - Interchangeability info on '99 F450 4x4 7.3D srw L3.73 rear end
post #3 of (permalink) Old 09-18-2018, 08:48 AM
RT
RT's Avatar
Could there be a typo in the title? He's saying a 99 F450 with a SRW 3.73? I'm not aware of any F450s that came with a single rear axle, and none of them were 3.73 gear ratio.
If the OP has any Sterling 10.5 SRW, then any other Sterling 10.5 SRW will be a direct bolt in. There apparently were some different load capacities from different years / models, but the outside structure should be the same - probably all the way to 2007 and maybe further.
RT is offline
