Diesel Forum - TheDieselStop.com - View Single Post - Interchangeability info on '99 F450 4x4 7.3D srw L3.73 rear end
post #4 of (permalink) Old 09-18-2018, 01:02 PM
DonWarkentin
Originally Posted by [email protected] View Post
Hey folks, Recently purchased this rig. Backed the trailer into a burm, put the pinion into the cage. I've opted to replace with a used one. Hoping to get some expert advise on years/models that will work. Specifically if 250's or 350's LS 3.73's in what years will fit? Thanks in advance..Bruce
Did it come from the factory that way, or was it modified by the previous owner?
DonWarkentin is offline
