Diesel Forum - TheDieselStop.com - View Single Post - Interchangeability info on '99 F450 4x4 7.3D srw L3.73 rear end
post #12 of (permalink) Old 09-20-2018, 03:03 PM
DonWarkentin
Originally Posted by bugman View Post
I would be nice to know that actual rear end that is in it.
I doubt that a Sterling 10.5 that comes with the F250 & F350 will go into that truck without some work.
Sounds to me as if the work has already been done, since the previous owner cut off the back part of the truck and welded on the back part of some SRW truck. We would have to know what truck he used as the donor for the short bed, SRW, 3.73. Probably whatever he used before would work again.
DonWarkentin is offline
