Diesel Forum - TheDieselStop.com - View Single Post - IDM or valve issue
post #2 of (permalink) Old 10-15-2018, 10:52 PM
klhansen
klhansen's Avatar
My Photos: (180)
I would suspect a defective replacement injector before a base engine issue, such as valve train.
The IDM failure code is probably a fluke. I've had that come up a few times, but have never had an IDM problem.
You could swap the #2 injector to another cylinder and see if the contribution fault follows it. If you put rebuilt injectors in, I would definitely suspect them.
Your injector provider is incorrect. Unless the '99 went in for the "cackle fix" and someone changed the #8 injector, it would have 8 AD injectors. The change to the AE in #8 required a PCM flash as well, and if not done would affect how it runs.
), AIS,
regulated return,
klhansen is offline
