Diesel Forum - TheDieselStop.com - View Single Post - IDM or valve issue
post #5 of (permalink) Old 10-16-2018, 08:02 AM Thread Starter
bomhour
Originally Posted by klhansen View Post
I would suspect a defective replacement injector before a base engine issue, such as valve train.
The IDM failure code is probably a fluke. I've had that come up a few times, but have never had an IDM problem.
You could swap the #2 injector to another cylinder and see if the contribution fault follows it. If you put rebuilt injectors in, I would definitely suspect them.
Your injector provider is incorrect. Unless the '99 went in for the "cackle fix" and someone changed the #8 injector, it would have 8 AD injectors. The change to the AE in #8 required a PCM flash as well, and if not done would affect how it runs.
klhansen, to be clear, I put in all AD reman'd injectors and it still runs rough. I will try putting one of the old AD's in the number 2 cylinder and see what result I get back. However, when I do a buzz test with all AD's, they all buzz.
is there a way to bench test the injectors on the truck? off the truck? I worry that I'll swap a bad injector with another bad injector.
bomhour is offline
