6th time in ~ 2 years I was left stranded with a no start, no CMP/CKP Synch, no FICM Synch on the Scanguage II. I replaced the CMP Sensor again ( I'm now an expert at this process having done it 7 times now), but this time, it DID NOT FIX THE NO START. The last time this happened, I replaced a 6 month old CMP with a Motorcraft CMP, and did the Pigtail repair also meticulously following the process to the letter. After that repair, the engine did not fire immediately, but did after several attempts which leads me to believe my engine harness may also be suspect. Yesterday, the "no start" left me stranded way back in the sticks with a 29.5' camper trailer... I drove 60 miles in our other truck to get another new CMP, replaced it, and the engine still did not fire. I messed with the harness a bit, and checked oil level, ICP, IPR, and a few other common "no start" causes... No CMP/CKP, no FICM Synch were still the cause. I then gave up and towed the truck out to the road about 7 miles on a very rough, bumpy, wash boarded road, and just for the hell of it, I tried to start it before calling a tow truck and it started................. We drove back in, hooked up the trailer and towed it back home... I'm now leaning towards some sort of engine harness problem, and most likely will replace it vs. try to diagnose it... I'm assuming this is another major surgery to replace the harness considering all the connectors that are involved... I'm assuming they are still in the $400 to $600 dollar range to purchase...?
