Diesel Forum - TheDieselStop.com - View Single Post - All terrain tires
post #4 of (permalink) Old 11-18-2018, 06:37 PM
DENNY
I would consider Bridgestone Blizzak. Not cheap but if you can't run studs the Blizzak is a great tire. I would avoid getting a wide tire, too much flotation on ice and snow will hurt traction. Get stock or narrower tire. Do you have 2WD or 4x4?
DENNY
DENNY is offline
