Diesel Forum - TheDieselStop.com - View Single Post - Fuse Panel Issue
post #4 of (permalink) Old 12-17-2018, 10:16 PM
klhansen
klhansen's Avatar
My Photos: (180)
Not sure about the '05's but I doubt there are that many unused wires available from the factory.
On '99-'03 7.3's there's one - count 'em - one wire that's available already wired into the fuse panel. It's labeled customer access and is hot with key on with a 10A fuse. There are also 4 pass thru wires going from the area by the driver's side hood hinge to the panel under the dash, but they're not connected on either end. All the wires are blunt cut with some heat shrink on them, not folded over.
), AIS,
regulated return,
klhansen is offline
