Diesel Forum - TheDieselStop.com - View Single Post - Replacing rigid fuel line
post #7 of (permalink) Old 12-29-2018, 12:18 PM
Steve83
Steve83's Avatar
Another option is hard nylon tubing, which is what Ford used/uses on many other vehicles. It's inexpensive, flexible, durable, & easy to work with. Bends can be made semipermanent with a common heat gun (or torch with fan shield). It will just slip onto the correct-sized hose barb, & seal without any clamp - just a drop of motor oil for lube.
(phone app link)
That's how Ford connected it to early ('84-91) plastic, brass, & stainless EFI fittings operating between 30-100 psi of gas, so it will easily handle 10 psi diesel.
(phone app link)
Steve83 is offline
