Diesel Forum - TheDieselStop.com - View Single Post - Suspected dirty injectors
post #7 of (permalink) Old 12-31-2018, 09:57 AM
bugman
bugman's Avatar
My Photos: (12)
Originally Posted by bluenavigator View Post
My truck is not exact OBD II compatible (maybe wrong word but...) - I can plug OBD II scanner but it wouldn't read/pull anything. I think that I need it to be reflashed or have correct scanner that can read OBD for PSD only. That's what I believe. If anyone have good scanner that can read the codes, please let me know. For my scanner, it is INNOVA 3130c "FIX Assist ScanTool w/ABS."
You need to get a scanner that can read Fords codes 99% of them out there can not read them. If you have a laptop check into Forscan. It is a free program that runs on a laptop and will do a lot of diagnostics on these trucks. If you don't have a laptop then look into what you can do with your phone.
https://www.powerstrokenation.com/fo...s-android.html
bugman is online now
