Diesel Forum - TheDieselStop.com - View Single Post - Odd injector cup problem
post #2 of (permalink) Old 01-03-2019, 01:43 PM
RT
RT's Avatar
As clean as the bottom edge is, it looks more like the dealership knocked the bottom out of the cup with a cheesy injector cup install tool. I suspect that if it had melted away from a bad copper washer seal, it would be a lot rougher edges. Which tool did you use on the reinstall? The Riffraff tool supports the cup at the flanges instead of the bottom.
RT is online now
