Diesel Forum - TheDieselStop.com - View Single Post - 2019 most dependable regulated return system?
post #4 of (permalink) Old 01-03-2019, 03:39 PM
DENNY
Sorry I missed the FRx in your sig. I don't have any problems with mine on two trucks, but I do not have the Airdog are you are you sure it is not the Airdog that is causing the issue? I am not sure if the pressure bleeds fuel pressure bleeds to zero when you shut down (khanson will know) If it does I guess you could have some kind of air leak into the system as it bleeds down but I expect to also see a fuel leak under pressure. Maybe a tear in fuel line inner rubber or O-ring acting like one way valve? I would call venders for both products and see if they have had a issue like that. Sucks to put two things on a truck to prevent a problem only to have it happen worse
DENNY
DENNY is offline
