Diesel Forum - TheDieselStop.com - View Single Post - Learn me on turbo rebuilding/replacement
post #1 of (permalink) Old 01-03-2019, 08:32 PM Thread Starter
jdkluge
I had a post on a turbo whine. Now I am sure it needs to be at least rebuilt. While I have it out and apart I might as well replace the wheels. It has the original parts and 280K mies. Iíll also install a set of bellowed up pipes. So my question is what are the best options. It is mostly a daily driver though I do tow equipment with it and want to keep my EGT low. It has more than enough power as it is with a stock turbo. I want to rebuild it to be strong as possible. I have read that with billet wheels there is an increase in the EGT but will spool faster.
What about a full turbo cartridge already rebuilt with new wheels?
Are ther any links on this topic I can read up on turbos. I have searched up old posts.
What else do I need to know? Special tools? Common mistakes?
Thanks in advance.
Late '99, F-250 7.3L, PSD, Super Duty, AT, 4X4, Crew Cab, 235 Mich tires, MBRP 4" Exhaust, 6-setting DP-Tuner (set for +80hp Econ mode), K&N Filter and Intake Tube, 203 thermostat, coolant filter, A-Pillar Isspro gauge set (pyro pre-turbo, trans temp, boost), Turbo Master Wastegate Controller, 6.0L tranny cooler, BTS valve body, rebuilt trans at 196K mi, bilstein shocks, HPOP rebuild, Fuel and oil crossover, Chevron Delo 400 10-40w, Zoodad mod, late model cup holder.
No time left for Drinking.
jdkluge is offline
