Diesel Forum - TheDieselStop.com - View Single Post - Learn me on turbo rebuilding/replacement
post #2 of (permalink) Old 01-03-2019, 09:17 PM
DENNY
I have not seen anything that says billet wills increase the EGT, lots of hype about just about aftermarket part on the truck so I would take it all with a grain of salt. If you can get a balanced center section with new wheels that sounds good. I would get the locking bolts for the center section. Good time to do a regulated fuel return while the turbo is out. Take a good look at the pedestal while turbo is out.
DENNY
DENNY is online now
