Diesel Forum - TheDieselStop.com - View Single Post - Here I sit waiting on a tow truck.
post #8 of (permalink) Old 01-10-2019, 07:06 AM
Xeonpony
12v is the most fire prone voltage, add the fact it is DC.
Grounds need to be clean, tight and well secured from becoming lose.
So start from there, check the wiring run from the starter to both the + terminals, ensure no chaffing of the wire and that all connections are clean and torqued.
Do the same for the grounds, then start looking at other places. A little resistance makes big heat when dealing with low voltage I^2R = heat in watts
New truck: 1988 F-350 1 ton dualy 2*4, 7.3L IDI Naturally Aspirated, Dual tanks with Camper package.
Mods: Enhanced gauge cluster; Transmission temp, rear diff temp, coolant system pressure, Vacuum pressure, Fuel pressure, Crappy tire Air horn Kit, Raycor pre filter/water sep. All LED Dash lighting, Parker LFS tranny filter, super duty tranny cooler, gerret turbo, waste gated (pending).
Xeonpony is offline
