Diesel Forum - TheDieselStop.com - View Single Post - Learn me on turbo rebuilding/replacement
post #11 of (permalink) Old 01-10-2019, 09:40 AM
brian42
brian42's Avatar
When I rebuilt my turbo I used the Garrett rebuild kit with the 270 degree bearing and the Riffraff billet wheel. Runs great and cured my surge.
As for special tools you will need to have a 1/4" drive 12-point 8mm socket otherwise you will not be able to remove the backing plate bolts. I also had a small Tupperware container with a pool of fresh oil to soak parts in before install. The rest is pretty straight forward. If you want to see what it entails here are good write-ups depending on which kit you go with:
270 degree bearing: https://www.riffraffdiesel.com/conte...structions.pdf
360 degree bearing: https://www.riffraffdiesel.com/conte...structions.pdf
The Money Pit
2003 F-250 7.3L PSD FX4 CCSB, Dual Alternators - 160/80 SS, T500, FRx, 6.0 IC & TC (w/Derale), S&B, RR 4/4 Wheel, EBPV-less, RR OCR, IH Up-Pipes, Hydra (PHP & GH), ISSPRO Gauges, FTVB, 4" MBRP, H&H, Racor PS120, 140A Alternators, North Stars, Dynatrac, XRF, ATS Springs
brian42 is offline
