Diesel Forum - TheDieselStop.com - View Single Post - Learn me on turbo rebuilding/replacement
post #13 of (permalink) Old 01-10-2019, 11:25 AM
RT
RT's Avatar
The parts come from the factory unit balanced. That means the exhaust and intake side were together when they were balanced. The tech then scribes the intake wheel and shaft and then reassembles the wheels and shaft in the turbo. When you take your intake wheel off and put a different one on - even if it is perfectly balanced - the unit may no longer be balanced. Using your analogy, it would be like having a tire and wheel assembly balanced and then changing the tire with a perfectly balanced tire (minus the wheel). Then when you reassemble the unit, it may not be perfectly balanced anymore. That's because some of the weights on the wheel were there to offset the previous tire. Same with the turbo. The exhaust side may have had some weight removed to help balance the intake side. Now, with a new, perfectly balanced wheel it is no longer balanced as a whole. And that's no none sense.
RT is online now
