Diesel Forum - TheDieselStop.com - View Single Post - Think I gelled up. What you think?
post #8 of (permalink) Old 01-30-2019, 06:50 PM
bugman
bugman's Avatar
My Photos: (12)
Just a FYI plugging it in won't help if it is gelling.
The gelling will be in the tank and fuel lines. The block heater only helps with the cold starts. It may be too late for you to check but pull the fuel filter and take a look at it and see if it has a wax build up on it. If it does it just might be your fuel.
Diesel 911 will help with gelled fuel and do nothing for the fuel pump except allow it to pump the fuel to the engine.
bugman is online now
