Diesel Forum - TheDieselStop.com - View Single Post - Cooling system troubles
post #8 of (permalink) Old 02-05-2019, 11:07 PM
ArcticDriver
ArcticDriver's Avatar
Originally Posted by jleedog View Post
I think you may have air trapped in the system. Try running without the degas cap on for a few minutes and look to see if the level drops. You could also try disconnecting the upper radiator hose and see if you are getting any flow out of it while it is running.
Good tricks.
Another is to repeatedly squeeze the upper radiator hose while engine is running and you should feel pressure.
My favorite trick is to go drive up and down steep mountain roads to get rid of air pockets...ofcourse, this works much better in CO than FL.
Did you actually see the coolant sensor break? Or it just quit working? Maybe worth looking at the pigtail connection closer.
Also, did you get the serpentine belt wrapped properly around the pulleys. Back when I used to trust my memory, I reinstalled the serp belt only to realize after that I installed it wrong around a couple pulleys.
Last thought, did you do anything with your thermostat during your waterpump replacement?
SOLD:
ArcticDriver is offline
