Diesel Forum - TheDieselStop.com - View Single Post - Cooling system troubles
post #15 of (permalink) Old 02-08-2019, 05:23 AM Thread Starter
Cwilbourn
Cwilbourn's Avatar
No the upper radiator hose would not get warm after driving it roughly 20 minutes and the degass bottle never had to have coolant added I would think that if the pump was pumping correctly then the air would be pushed out and I would need to add coolant I drove the truck a few short drives since I've installed the new pump and never had to add coolant I was able to install the thermostat without losing much coolant and still it hasn't emptied the degass bottle it's a murry I should have went to Ford I guess I forgot the lower rad. hose wasn't hot either
Curtis
Cwilbourn is offline
