Diesel Forum - TheDieselStop.com - View Single Post - Best FIRST START-COLD START advice
post #4 of (permalink) Old 02-09-2019, 05:40 PM
RT
RT's Avatar
I would probably pull the glow plugs and spray a liberal amount of WD-40 or marvel mystery oil into the cylinders. I would then turn the motor over a few revolutions by hand, then spin it with the starter until your oil pressure came up. Then you can button it up and start it. I wouldn’t invest in any other maintenance parts until you know it’s going to run. Why spend a lot of $$$ and then find out you broke a ring or something.
RT is offline
