Diesel Forum - TheDieselStop.com - View Single Post - Frozen Tundar Cascading electrical failure mid-winter blues
post #6 of (permalink) Old 02-11-2019, 05:26 AM
clydesdale
My Photos: (5)
You said that is stalled. Was it initially running? Did you simply gel the fuel? Although, with that, if you plug the block heater, I would think it might start and run momentarily. Because of NY winters and occasional run to VT, I only use the 5w 40 syn rotella. It is good from NY to FL and it spins much faster on start up than with 15w 40.
2002 F-250, PSD 6-speed, CC, short bed, 4X4, Toreador Red w/ Silver accent, A.R.E mx cap, Weld Super Single II and 33s in the summer, x-springs, F-350 blocks and badges, AIC, proflaps, ITP intank mod, AirDog with 3 micron filter, isspro guages and TTM, scangauge, husky liners, alarm, xm stereo,stull 5399-p grille, centramatics, ccv mod, AIS Air Filter, Southbend CON O, Detroit Truetrac LSD, coolant filter, 203 stat with billet housing, blackcloud intake heater plug/boost fitting, reese titan hitch, fabcraft PTO cover/temp sender port, prodigy brake controller, ITP Boost Annihalator, oilguard bypass filter, Mag-Hytec rear dif, bilsteins, hellwig rear stabilizer bar, ATS housing, non-ebpv pedistal and exhaust flange, magnaflow 3.5dp exhaust, ITP reg return, turbomaster wastegate controller, and ceramic coated bellowed up pipes, PHP 50t and 80p, currently 127,000 miles.
clydesdale is offline
