Diesel Forum - TheDieselStop.com - View Single Post - Frozen Tundar Cascading electrical failure mid-winter blues
post #8 of (permalink) Old 02-13-2019, 06:26 AM
ArcticDriver
ArcticDriver's Avatar
Does this mean you did not have the new cord & element installed?
If you opted not to pay $300 then you may be happy to learn you can buy an aftermarket cord on amazon for under $25 and its a simple project to replace only the cord and leave the original heating element installed (which requires draining a bunch of coolant if it had to be removed). The cord simply unplugs from the element which is located in the aluminum housing your oil filter screws into and then you just have to route the new cord to the front bumper and tie it about 4 places with cable ties to hold it in place.
The cord is a very common failure even though the heating element continues to work fine. The element seldom fails.
I think most members will agree that the block heater is a superior method to warm your engine block instead of the magnetic oil pan heater. It would be good to fix the cord.
SOLD:
ArcticDriver is offline
