Diesel Forum - TheDieselStop.com - View Single Post - Advice on safe interstate RPMs 65-80 mph
post #8 of (permalink) Old 03-14-2019, 11:08 PM Thread Starter
Austin_ce
Originally Posted by bugman View Post
I wouldn't worry about the RPM's at all. As I mentioned there is a govenor in the PCM that is set at a certain RPM, I think it is 3500 RPM's but I am not sure and you can run it at that point all day long.
As for regearing you have a 4x4 so you would also have to do the front end.
yea I have the front drive shaft removed right now, assuming the front gear ratio isn’t really considered until 4x4 is engaged.
Austin_ce is offline
