Diesel Forum - TheDieselStop.com - View Single Post - 7.3l misfiring/surging in only one DP Tuner chip position?
post #2 of (permalink) Old 04-06-2019, 01:17 AM
2000F250-7.3
2000F250-7.3's Avatar
It could be the switch it self acting up in the one position. It could be the connection has what I would call o zone build up or the connection has come loose. It might be a shot to pull the chip out and look at everything and reinstall and test again.
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
2000F250-7.3 is offline
