Diesel Forum - TheDieselStop.com - View Single Post - Welderup
Thread: Welderup
post #8 of (permalink) Old 04-21-2019, 09:00 PM
Big Horn
Big Horn's Avatar
If there’s good steel in the frame yet, do your measurements, cut frame on a bias, bevel and weld 100%, then weld a football patch of slightly heavier gage steel over the splice and you’ll be good to go!
2002 F350 7.3L / 4R100 - 4WD CC DRW 8 Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is offline
