Diesel Forum - TheDieselStop.com - View Single Post - Steering Column Slop Removal
post #1 of (permalink) Old 05-11-2019, 11:36 AM Thread Starter
geezer88
I've got an '88 F250 4x4 diesel that isn't worth putting a lot of money into, but the slop in the steering column sliding joint was driving me nuts. I found I could slip an .018" feeler gauge into the joint, so I got to thinking of ways to keep a shim in place. I found an old clock spring that was .250" x .020" in cross section. It is good hard steel, so I cut two pieces, each four inches long. I pushed them as far as possible into the gap. The flat on the inner shaft is just a little wider than .500", so the two strips fit well. To keep them in place, I bent them back over the outer shaft and held them in place with a hose clamp. See picture. Only driven it a few miles so far, but it feels so much better not having to work so hard keeping it between the fence posts. tom
1988 F250 7.3 idi 3/4ton 4x4
geezer88 is offline
