Diesel Forum - TheDieselStop.com - View Single Post - Tire Pressure Q
Thread: Tire Pressure Q
post #6 of (permalink) Old 06-10-2019, 12:38 PM
DonWarkentin
The Bridgestone and the Michelin charts are nearly identical, with three exceptions:
1. Michelin chart shows the weight rating for the entire axle, while Bridgestone chart shows the weight rating for the individual tire.
2. Michelin chart shows the weight rating for duals down to 65psi, while Bridgestone chart shows it down to 70psi.
3. Michelin chart shows the weight rating for singles down to 65psi, while Bridgestone chart shows it down to 80psi.
DonWarkentin is offline
