Diesel Forum - TheDieselStop.com - View Single Post - White & Black Smoke - Hope I didn't trash engine
post #13 of (permalink) Old 06-22-2019, 01:26 AM
bismic
Well, I wish you well w/ the injector from Injector Direct. Probably not a problem - especially since you don't have real long term plans for the truck and it already has quite a few miles!
The key with a remanufactured injector is who does the remanufacturing, not so much whether they start w/ an OEM core (and although a quick visual inspection is always good, it is hard to tell much without a teardown).
Ford uses Pure Power to rebuild the injectors (used to be Siemens, but Pure Power is a spin off company of the Siemens and International joint venture). They do an exceptional job. According to their advertising, it certainly does look like Injectors Direct sells the same part as what you would get from Ford (one of their 4 options), AND they seem to sell the brand new ones (only produced by Pure Power).
Searching for feedback on them generally looks good, but there are some bad experiences out there also. Thing about parts like injectors though - success is not something determined in a year or two.
Mark
bismic is online now
