Diesel Forum - TheDieselStop.com - View Single Post - rear tires
Thread: rear tires
post #2 of (permalink) Old 06-25-2019, 05:48 PM
klhansen
klhansen's Avatar
My Photos: (180)
Your tires are the stock size for your truck. For older trucks (my 99 for instance) used 235/85-R16's stock with the 265's as optional. I know that 285/75-R16's have been used on stock wheels, but they'll be a bit taller, and probably won't make an appreciable difference in the sway that you're experiencing. You'd also need to get the speedo recalibrated for the different revs per mile.
), AIS,
regulated return,
klhansen is offline
