Diesel Forum - TheDieselStop.com - View Single Post - rear tires
Thread: rear tires
post #3 of (permalink) Old 06-26-2019, 01:47 AM
DENNY
Do you have a rear sway bar? If so consider upgrade to a bigger one. I don't think the tire will help much if you are at max pressure to start with.
DENNY
DENNY is offline
