Diesel Forum - TheDieselStop.com - View Single Post - Truck pulls hard left the longer I drive
post #12 of (permalink) Old 07-01-2019, 08:36 AM Thread Starter
acade
acade's Avatar
Originally Posted by RT View Post
Also, it is highly, highly recommended to replace brake parts in pairs. If one side is bad, the other can't be far behind and you really want your brakes to be equivalent side to side.
In general, I agree, and I appreciate the advice. The other side looked fine from a visual inspection. The pads are still in great shape and the slide pins move freely. I think I'll leave it alone for now, but if it happens again, I'll know what the problem is.
2000 F350 4X4 XLT CCLB SRW 7.3L ZF6
8.5" Pro Comp lift
16x12 M/T Classic IIIs with 38x15.50 Toyo Open Country M/T rubber
Riffraff Diesel 6637 intake, CCV mod, HPX, AIH delete, CAC boots/clamps/plenum inserts
Riffraff Diesel Coolant Filtration System, Billet Thermostat Housing
MBRP 4" SS straight exhaust
LuK clutch kit
Edge CS2 programmer
VIAIR on-board compressor w/Kleinn air horns
Amp Research Power Steps
2016 tailgate conversion
Iron Cross bumpers w/Rigid Dually LEDs
DeeZee tool box
Gooseneck hide-a-hitch
acade is offline
