Diesel Forum - TheDieselStop.com - View Single Post - Battery generator block heater
post #12 of (permalink) Old 07-08-2019, 04:18 PM
klhansen
klhansen's Avatar
My Photos: (180)
So that's a battery/inverter package, that's capable of being recharged with a generator. I see it's rated for 288 WH which means it would last less than 20 minutes if loaded at 1000W. The battery would be drained in short order. Not going to help much
What everyone else said about keeping your glow plug system and starting batteries up to snuff. I once started my cold-soaked truck at minus 6F without a working block heater or a working glow plug system. When it finally fired off, I mosquito fogged the whole neighborhood (if there had been any mosquitoes around at that temp). With a working GP system and good batteries, you should have no problem starting without a block heater plugged in well below zero.
), AIS,
regulated return,
klhansen is offline
