Diesel Forum - TheDieselStop.com - View Single Post - Do I have a clutch problem or tranny issue?
post #3 of (permalink) Old 07-17-2019, 12:48 AM
klhansen
klhansen's Avatar
My Photos: (180)
I'm not so sure it would be a throwout bearing. That would likely make noise any time the clutch pedal is depressed. But even if it is, the tranny will have to come out anyway. It could be the pilot bushing. I had a SB kevlar pilot bushing go out on me. It would so the signature "shaft rattling around in a bore" sound. I was worn enough that I could stick a 1/8" allen wrench alongside the input shaft in the bushing. With the clutch sticking engaged occasionally, I would also suspect the disc springs or the center of the disk coming apart. I've had the center hub of the disk let go on me as well. I was thinking "Oh crap, the input shaft broke", but fortunately, the tranny was fine.
Let us know what you find when you tear into it.
), AIS,
regulated return,
klhansen is offline
