Diesel Forum - TheDieselStop.com - View Single Post - DRW - 3.55 vs 4.10
post #9 of (permalink) Old 07-22-2019, 01:00 PM
DonWarkentin
4.10 can make it up the hills faster when towing 17k-18k. 3.55 gets better mpg when not towing. Which is more important to you?
DonWarkentin is offline
