Diesel Forum - TheDieselStop.com - View Single Post - Best “performance” muffler to tame the sound of a 4-inch straight pipe?
post #10 of (permalink) Old 08-01-2019, 09:20 PM
DonWarkentin
Here's what FTE says, "No gain in EGT or reduction in flow" https://www.ftediesel.com/store/pc/v...6&idcategory=7
However, previously they said, "There is very little backpressure, no significant egt gain, and the noise cancellation properties are awesome." https://www.cumminsforum.com/forum/f...available.html
So I guess there is either no gain in EGT or no significant egt gain.
DonWarkentin is offline
