I have searched many forums and can not find the rubber part that goes from the CDR to the pan for the ATS turbo on a 1986 6.9, can someone get me the part number for a 6.9 1986.
Here is what I have gathered from the various threads that work fine for the 7.3 and can not find a good picture. Just on one russian site seems to be a straight piece, where mine has a right angle.
Rubber tube from CDR to pan - E8TZ-6A892A $7.35
Grommet from CDR to intake - E3TZ-6A892A $3.08 1805292C1, SEAL, CRANKCASE VENT VALVE, INTERNATIONAL/NAVISTAR,1654/4600,1988-90
CDR (Adapter Assembly) - E3TZ-6A665A $62.57 IH pt# 1805319C1,
here is the russian website with picture of straight tube, mine has a bend.
Here is an option that I found that may work,it is for a 6.5 td truck Do not know the diameters
CDR Valve Connector Hose :: SSDiesel Supply :: GM 6.5 TD Specialists
http://72.236.255.169/img/products/1368588726_CDR-Valve-Connector-Hose.jpg
6.5 CDR Valve Grommet :: SSDiesel Supply :: GM 6.5 TD Specialists
I have a 1990 ATS turbo and it is completely different. it has a straight hose.
So can someone tell me is the above part number E8TZ-6A892A is a right angle or is different. and if someone does have the ATS turbo part number one.
I have done a temp patch of a oversize hose over with silicone seal for now.
