Diesel Forum - TheDieselStop.com - View Single Post - 500 miles post injector job madness
post #10 of (permalink) Old 10-16-2019, 11:15 PM
DENNY
Look above posts for your user name, click on it, drop down to modify signature, get er done. I am a bit worried that the fuel cleaner is pointing to the injectors. Los of the cleaners also contain a lube, that would point to a sticking injector. Klhansen may drop in on this post to add advice I have him on speed dial for my problems and I would follow his advice over mine (unless I disagree of course) Did it run fine for 500 mi and then start symptoms? Crawl under the truck and see if you have a wet exhaust on one side or the other.
DENNY
DENNY is offline
