Diesel Forum - TheDieselStop.com - View Single Post - 92 F700 injector pump problem?
post #2 of (permalink) Old 11-03-2019, 10:33 AM
nevrenufhp
nevrenufhp's Avatar
Did you change the fuel/water separator/filter too? There could also be something in the tank that's stuck at the pickup tube. The rev on its own is an odd one. I'm thinking the pump, maybe, but best to eliminate the other problem first. Check fuel pressure at the pump, and amount of vacuum at the tank.
commuter: 08 VW R32, or 67 F100,300,offy intake,edel carb,274* cam,header
Work truck:'94 IH 4900, DTA466 lightly bombed(#0 fuel plate, timing at 22*, 3 clicks tighter gov springs), Allison MT653, Voith retarder, and straight piped
nevrenufhp is offline
