dead links (question inside) - Diesel Forum - TheDieselStop.com
News, Comments, Site Help and Suggestions Discussion of TheDieselStop.Com itself. What do you like or don't like, kudos and complaints, comments and suggestions.
post #1 of 4 (permalink) Old 01-03-2004, 03:42 PM Thread Starter
Not sure which forum this belongs, figured this might be the best, if not, feel free to move it.
I have ran across a couple of posts (archived) that have several links to other threads with helpfull info. Is there a way to change the url's so they direct you to the proper thread (instead of the no forum found page). Something I can do (and maybe post the updated links)?
Thanks!
Some people dream of fame and wealth, others work for it.
Lynn Amick
'00 F250 SD 7.3PSD S/C, Hillbilly intake sys, CCV mod, 4 position chip, EBPV switch, 4"DP DPPI exh, HX hose, remote fuel drain handle, coolant filter, turbo timer. Cardboard fiber dash kit still in the works.
Lots of things on the "to-do" list
AmickRacing is offline
post #2 of 4 (permalink) Old 01-03-2004, 04:26 PM
My Photos: (11)
Re: dead links (question inside)
Thanks!
Please check your PMs and let me know if that works and if so, I'll post the method here.
Larry
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, <font color="blue">Mustang dyno - 183.9/400.4 stock</font>
, BTS w/Schaeffer's ATF
, ITP 3.5"/4" exhaust w/Magnaflow & Aeroturbine,Dieselsite 203* T-stat/Zerex G-05,F.Pwr, Ext/Int. Upgd. pkg,R. Bds,AIC,Tow Pkg, Rear & Slider windows,<font color="red">AMSOIL air, oil-bypass & rear end 75w-140 fluid ,<font color="blue">3/8" fuel sys w/10 Dieselsite DAHL100 & fuel manifold/sight glass</font>,6 way dr. pwr. seat, Magnefine trans/P.S. filters</font>, husky mats,<font color="red">5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges</font>,Dieselsite coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets"
, & a 1981 26' Prowler TT(26Y)
Larry M is offline
post #3 of 4 (permalink) Old 01-04-2004, 03:02 PM
My Photos: (11)
Retriving broken/dead links
For all those having issues with finding broken links to the archived section of the site there is a utility that will find these <font color="red"> HERE</font>. What you have to do is type in the Thread ID # (not a post #) and it will return a link to that Thread ID. You can get the Thread ID number by either clicking on the broken link directly and finding the Thread ID in the address bar or right clicking on the broken link and finding it under the properties. The former is probably best since you will already be there when you discover the link is bad. Only hiccup that might exist is when a link is done to a certain post within a thread using the "threaded mode", I don't think that the number in the link for the Post # in that thread will work with the utility will work for Post #, just Thread IDs so make sure you use the Thread ID to be safe.
This utility might not be a permanent feature or be incorporated in some other way and if that happens I'll try and update the status of this utility here.
Larry
Larry M is offline
post #4 of 4 (permalink) Old 09-12-2004, 08:22 PM
My Photos: (6)
Re: Retriving broken/dead links
This thread needs to be a sticky or, even better, create a link to the utility page on the archive search page!
'04/04 F350 SRW Lariat CC LB <font color="CCCCCC">Silver</font> 6.0 T/S 4x4 X-springs , Dual Alts, AIC, Bilsteins,
, CB - overhead mount, QuadPod w/Cobalts,
NRA Endowment Member
bullseye is offline
  Diesel Forum - TheDieselStop.com > General Discussion > News, Comments, Site Help and Suggestions
